Alphacool HT 16mm HardTube screw-on sleeve 90° L-connector - knurled - Chrome
  • 17297
  • 4250197172974
  • 0,097 kg
€7.28 *
With the new screw-on nozzles from Alphacool for acrylic, brass or carbon tubes, Alphacool is... more
With the new screw-on nozzles from Alphacool for acrylic, brass or carbon tubes, Alphacool is taking another step towards perfection and quality.
The first two colors, Chrome and Deep Black, offer great variety. The completely coordinated product series lets each system shine in its own way and there are no limits to individuality when combined with Alphacool acrylic brass tubes!
A new chromating process firmly bonds the coloring to the brass base. This ensures the longevity of the intense color and prevents the chrome layer from chipping. Alphacool lettering on the connections further highlights the special nature of these items.
This connector is used to connect two 16mm acrylic, brass or carbon tubes with a 90° angle.
Dimension:
  • Width: 41.5mm
  • Height: 41.5mm
Technical details:
  • Material: brass, chromated
  • Color: Chrome
1 x Alphacool HT 13mm HardTube screw-on sleeve 90° L-connector for acrylic brass tubes - knurled - Chrome
ANS Alphacool HT 16mm HardTube Anschraubtülle G1/4 - gerändelt - Chrome Sixpack PHT EOL
Alphacool HT 16mm HardTube screw-on nozzle G1/4 - knurled - Chrome Sixpack
€28.98 *
€26.98 *
€41.98 * €59.98 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€21.63 * / 100 Zentimeter)
€38.98 *
S16 Alphacool HardTube 16/11mm Borosilikatglas 60cm
Alphacool HardTube 16/11mm borosilicate glass 60cm
Content 60 Zentimeter (€23.30 * / 100 Zentimeter)
