Alphacool Eiszapfen 13mm HardTube screw-on nozzle 45° rotatable G1/4 - Chrome
- Article no.: 17406
- EAN: 4250197174060
- Weight: 0,064 kg
- Available: Currently there are 6 available
*1Alphacool's Eiszapfen connection series is the high-end version of the proven connections!
Design: 45° screw-on nozzle 13mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 16mm acrylic and brass tube. In the middle, this connector is angled at 45° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
- Material: Brass
- Color: Chrome
dimension
- Length: 44.5mm
- Width: 21mm
Scope of delivery
- 1x Alphacool Eiszapfen 13mm HardTube screw-on nozzle 45° rotatable G1/4 for acrylic brass tubes - Chrome
Here you will find an interactive overview of all Alphacool connections.
