Alphacool Eiszapfen 13mm HardTube compression fitting 45° L-connector - knurled - chrome
- Article no.: 17402
- EAN: 4250197174022
- Weight: 0,1 kg
Alphacool's Eiszapfen connector series is the high-end execution of these tried-and-true fittings!
Everything you want in a compression fitting is here: highflow, form, processing and colour. A refusal to compromise in development and production has made the Eiszapfen series into what it is. Fittings are available in brilliant chrome or a deep, matte black, which will fit excellently into any system.
A special procedure binds the outer coating firmly to the surface, improving the longevity of the intense colour and preventing any chipping or peeling of the coating. Every connector now has the Alphacool logo, which along with their distinctive shape makes them unmistakable!
The union nut's slanted corners allow the O-ring to be pressed firmly against the HardTube, ensuring it sits even more securely than before. This allows for greater safety in transport.
Model: 45° compression fitting 13mm plexi / brass tubes
This fitting is suitable for 13mm plexi or brass tubes on both sides. This fitting is bent 45° in the middle to avoid complicated hose connections.
Technical Specifications
- Material: brass
- Colour: chrome
Dimensions
- Length: 46mm
- Width: 20mm
- Height: 33mm
Scope of Delivery
- 1x Alphacool Eiszapfen 13mm HardTube compression fitting 45° L-connector for plexi- brass tubes - chrome
You can find an interactive map of all Alphacool fittings here.
Gewindelänge: | 5mm |
1. Seite: | G1/4" Außengewinde |
Drehbar: | Ja - 360° |
2. Seite: | 13/10mm (ID 3/8" OD 1/2") |
Spezifikation: | Form: 45° gewinkelt |
Material: | Messing |
Farbe: | chrom |
Kompatibilität: | Acrylrohre, Carbonrohre, Messingrohre |
![ANS Alphacool HT 16mm HardTube Anschraubtülle G1/4 - gerändelt - Chrome](https://aquatuning.shop-cdn.com/media/image/a6/a4/66/1011013_1ylszDDNydjzjb_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
![S13 Alphacool HardTube 13/10mm Acryl (PMMA) Klar 60cm - 4er Set (240cm)](https://aquatuning.shop-cdn.com/media/image/e5/35/00/1011139_1tpeAFGXweWDiv_200x200..jpg)
![ANF Alphacool Eiszapfen L-Verbinder drehbar G1/4 AG auf G1/4 IG - 4pcs Set Chrome](https://aquatuning.shop-cdn.com/media/image/dc/30/b9/1022490_17XfWL7FRwAIhi_200x200..jpg)
![ANS Alphacool Eiszapfen 13mm HardTube Anschraubtülle 90° drehbar G1/4 für Plexi- Messingrohre - 4pcs Set Chrome](https://aquatuning.shop-cdn.com/media/image/79/14/71/1022482_175NtIjx4qM1ji_200x200..jpg)
![ANS Alphacool HT 13mm HardTube Anschraubtülle G1/4 - gerändelt - Chrome Sixpack](https://aquatuning.shop-cdn.com/media/image/b3/4e/6e/1012841_1_200x200..jpg)
![ANS Alphacool Eiszapfen 13mm HardTube Anschraubtülle G1/4 - Chrome Sixpack](https://aquatuning.shop-cdn.com/media/image/9a/0b/4c/1012835_1_200x200..jpg)
![S13 Alphacool HardTube 13/10mm Acryl (PMMA) Klar 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/2e/b1/fa/1011140_1umz2Aqz46Z8f7_200x200..jpg)
![WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 XC3 Ultra Gaming mit Backplate EOL](https://aquatuning.shop-cdn.com/media/image/11/15/7f/1021471_1Y1P0t0nurHpEL_200x200..jpg)
![S13 Alphacool HardTube 13mm OD 90° Messing 10/50cm Chrome](https://aquatuning.shop-cdn.com/media/image/d2/0d/df/1019303_1YfRIwtIHPhe4K_200x200..jpg)
![S13 Alphacool HardTube 13mm OD 90° Messing 20/40cm Chrome](https://aquatuning.shop-cdn.com/media/image/bd/55/67/1019302_1bYni0TbieELBb_200x200..jpg)
Liefertermin: in 8 - 9 Wochen
![S13 Alphacool HardTube 13mm OD 90° Messing 10/30cm Chrome](https://aquatuning.shop-cdn.com/media/image/86/3a/aa/1019301_1_200x200..jpg)
![PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe](https://aquatuning.shop-cdn.com/media/image/84/84/25/1019164_1VI1uAaOVHpQG4_200x200..jpg)
![L12 Alphacool Eiszyklon Aurora LUX Digital RGB - 3er Kit (120x120x25mm) EOL](https://aquatuning.shop-cdn.com/media/image/a5/05/80/1015791_1_200x200..jpg)
![KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/8a/a3/5b/1014216_1ZA9Tur4PPKavW_200x200..jpg)
![RAB Alphacool NexXxos Lüfterbefestigungsschraube M3 x 35 mm - 4 Stück](https://aquatuning.shop-cdn.com/media/image/5f/a2/g0/1013506_1o2HD5TJ90jrIf_200x200..jpg)
![S13 Alphacool Eisrohr 13/10mm PETG HardTube 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/2b/37/9c/1012517_1lZfAM00dwlPq0_200x200..jpg)
![S13 Alphacool Eisrohr 13/10mm Acryl (PMMA) HardTube Satin 80cm - 4er Set (320cm)](https://aquatuning.shop-cdn.com/media/image/84/8e/de/1012479_1WGaRRcS2Rfra8_200x200..jpg)
