Alphacool Eisblock Aurora Acryl RTX 4080 Strix with Backplate
- Article no.: 13530
- EAN: 4250197135306
- Weight: 1,7 kg
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Asus ROG Strix GeForce RTX 4080 OC, ROG-STRIX-RTX4080-O16G-GAMING, 16GB GDDR6X (90YV0IC0-M0NA00)
- Asus ROG Strix GeForce RTX 4080, ROG-STRIX-RTX4080-16G-GAMING, 16GB GDDR6X (90YV0IC1-M0NA00)
- Asus TUF Gaming GeForce RTX 4080 OC, TUF-RTX4080-O16G-GAMING, 16GB GDDR6X (90YV0IB0-M0NA00)
- Asus TUF Gaming GeForce RTX 4080, TUF-RTX4080-16G-GAMING, 16GB GDDR6X (90YV0IB1-M0NA00)
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X OC Edition
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X White Edition
- Asus ROG Strix GeForce RTX 4080 SUPER 16GB GDDR6X White OC Edition
- Asus TUF Gaming GeForce RTX 4080 SUPER 16GB GDDR6X
- Asus TUF Gaming GeForce RTX 4080 SUPER 16GB GDDR6X OC Edition
Technical data cooler | |
Dimensions (L x W x H) | 220,90 x 157 x 34,10mm |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Illumination | 11x digital aRGB LEDs |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 220,90 x 132,50 x 6mm |
Material | Aluminum |
Color | black |
Made in: | China |
Cooler type: | Complete cooler |
Material base plate: | Copper; |
Material Lid: | Acrylic; |
SLI compatible: | Yes |
Dimensions: | 220,90 x 157 x 34,10mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 4080; |
Notice: | Compatible up to 16/13mm straight; Compatible up to 19/13mm angled; |
