Alphacool Core HardTube Metall Cutter 7-31mm
  • 13428
  • 4250197134286
  • 0,184 kg
€20.98*
ZSO Alphacool Eistools assembly gloves size L - Black EOL
€1.48*
S13 Alphacool HardTube 13mm OD Brass Chrome 40cm
€16.98*
S13 Alphacool HardTube 13mm OD 90° Brass 10/30cm Deep Black
€19.98*
SZ Alphacool Apex Heat Gun with LCD 2000W 80-650°C
€39.98*
With the Alphacool HardTube Metal Cutter, cutting metal tubes becomes easy. Without flex and... more
With the Alphacool HardTube Metal Cutter, cutting metal tubes becomes easy. Without flex and without much effort, brass tubes, for example, can be easily processed.
Easy to use
The small, hand-operated HardTube Metal Cutter fits perfectly into any toolbox at home. Handling the cutter is uncomplicated. The first step is to clamp the tube between the rollers and the cutting blade. Then tighten the cutter blade at the desired position using the dial and slowly rotate the cutter around the tube. The cutter is regularly tightened as it moves around the pipe. That's it. This is how quickly and safely the HardTube Metal Cutter cuts.
Dimensions (L x W x H)83 x 52 x 31mm
Weight180g
Tube diameter7-31mm
colorblue
Alphacool HardTube 13mm OD Brass Deep Black 40cm
€28.98 *
€37.98 *
€37.98 *
Alphacool HardTube 13mm OD 90° Brass 20/40cm Deep Black
Alphacool HardTube 13mm OD 90° brass 10/30cm chrome
Content 40 Zentimeter (€49.95 * / 100 Zentimeter)
€23.98 *
