Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 - Chrome
  • 17392
  • 4250197173926
  • 0,074 kg
Version: 90° screw-on nozzle 13mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 13mm acrylic and brass tube. In the middle, this connector is angled at 90° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
  • Material: Brass
  • Color: Chrome
dimension
  • Length: 42.5mm
  • Width: 21mm
Scope of delivery
  • 1x Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic brass tubes - Chrome
Here you will find an interactive overview of all Alphacool connections.
€20.98 *
€37.98 *
€36.98 *
Alphacool HardTube 13mm OD 90° brass 10/30cm chrome
Content 40 Zentimeter (€49.95 * / 100 Zentimeter)
€23.98 *
€25.98 *
Alphacool HardTube 13mm OD 90° brass 20/40cm chrome
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
