Alphacool Aurora XPX RGB Frame - Black
  • 12893
  • 4250197128933
  • 0,034 kg
€3.99 * €9.95 * (59.9% Saved)
KAB Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm EOL
€1.98*
Highlights very easy assembly 15 RGB LEDs for perfect lighting Compatible with all... more
Highlights
  • very easy assembly
  • 15 RGB LEDs for perfect lighting
  • Compatible with all standard RGB controllers
  • For the Eisblock XPX satin or clear CPU cooler
The Alphacool Aurora XPX RGB Frame is designed for anyone who wants to perfectly illuminate the Eisblock XPX CPU cooler. The RGB Frame is simply placed over the Eisblock XPX cooler and then connected to an RGB controller. With an incredible 15 RGB LEDs evenly distributed around the XPX Eisblock CPU cooler, perfect lighting is guaranteed.
The RGB controller can be used not only to change the colors, but also to create color effects such as overflows, flashing, slow color changes and much more. Many controllers also have a dimming function. This makes the Alphacool XPX RGB Frame an all-rounder in RGB lighting.
With the 4-pin 12V RGB connector, all Alphacool RGB products are compatible with the common RGB sync technologies of all well-known motherboard manufacturers (ASUS, AROCK, MSI and GIGABYTE).
  • Dimensions: 75 x 75 x 17mm
  • Cable length: 40cm
  • Connector: 4Pin RGB
  • Material: POM, soft touch surface
  • Number of LEDs: 15
  • Control: separate RGB control (not included)
Scope of delivery
  • 1x Alphacool Aurora XPX RGB Frame - Black
Datasheet
54%
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
€0.99 * €4.89 *
€10.98 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Chrome PHT EOL
€3.99 * €9.95 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€25.98 *
63%
€1.58 * €4.28 *
€1.89 *
