Alphacool Eiszapfen 13mm HardTube screw-on nozzle G1/4 - Chrome
  • 17263
  • 4250197172639
  • 0,036 kg
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€20.98*
€25.98*
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
Design: HardTube screw-on nozzle 13mm
This connection has a 1/4" external thread on one side. HardTubes with an external diameter of 13mm can be screwed on the other side.
Technical details:
  • Material: Brass
  • Color: Chrome
Dimension:
  • Diameter: 21mm
  • Height: 16mm
  • 1x Alphacool Eiszapfen 13mm HardTube screw-on nozzle G1/4 for acrylic brass tubes - Chrome
€36.98 *
Alphacool HardTube 13mm OD 90° brass 20/40cm chrome
€25.98 *
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
€23.98 *
€20.98 *
€33.98 *
Alphacool HardTube 13mm OD 90° brass 10/30cm chrome
Content 40 Zentimeter (€49.95 * / 100 Zentimeter)
