Alphacool Eiszapfen 12mm HardTube screw-on nozzle G1/4 - Chrome
  • 17283
  • 4250197172837
  • 0,021 kg
€1.99 * €4.97 * (59.96% Saved)
With the "Icicles", Alphacool has created a true masterpiece. These connections promise absolute... more
With the "Icicles", Alphacool has created a true masterpiece. These connections promise absolute tightness and high quality.
Suitable for all hard metal pipes with an outer diameter of 12mm. On the other side of the connection there is the usual ¼” thread. Available in deep black and chrome.
First, the union nut is put on the pipe, followed by a plastic washer that protects the O-ring and the thick O-ring itself. Now the pipe is simply put into the connection in which the second O-ring is already sitting, which fits very tightly against the pipe. As a last step, the union nut is pushed onto the connection and screwed on.
Due to the size, the union nut cannot be screwed on tightly enough. But this has also been thought of, as an 8 mm hexagon key can be inserted from below to hold the connection in place.
scope of delivery
  • 1x Alphacool Eiszapfen 12mm HardTube screw-on nozzle G1/4 - Chrome
2nd page: 12/10mm
Rotatable: No
Color: chrom;
Thread length: 5mm
Compatibility: Acrylrohre;harte Schläuche (PUR);Carbonrohre;
Material: Messing;
Specification: Shape: straight
1st page: G1/4" external thread
Content 240 Zentimeter (€4.16 * / 100 Zentimeter)
ANK Alphacool ES Schnellverschluss BLH1A PushIn Set IG-IG
Alphacool ES Quick Release BLH1A PushIn Set IT-IT
€36.98 *
Delivery date: in 3 - 4 days
€21.98 *
32%
S13 Alphacool Eisrohr 12/9mm PETG HardTube 80cm - 4er Set (320cm) PHT EOL
Alphacool ice tube 12/9mm PETG HardTube 80cm - set of 4 (320cm)
Content 320 Zentimeter (€4.68 * / 100 Zentimeter)
€14.98 * €21.98 *
WAK Alphacool Core Geforce RTX 5070 Reference mit Backplate
Alphacool Core Geforce RTX 5070 Reference with Backplate
€199.98 *
WAC Alphacool Core 1 LT Black
€74.98 *
