Alphacool Core Geforce RTX 5070 GamingPro with Backplate
- Article no.: 14742
- EAN: 4250197147422
- Weight: 1,266 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Palit GeForce RTX™ 5070 GamingPro (NE75070019K9-GB2050A)
- Palit GeForce RTX™ 5070 GamingPro OC (NE75070T19K9-GB2050A)
| Technical data cooler | |
| Dimensions total (L x W x H) | 186,00 x 125,57 x 34,07mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 7 |
| Color | transparent |
| Dimensions (L x W x H) | 186,00 x 97,00 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
