Alphacool Eisbaer Quick-Connect Extension Kit
  • 12548
  • 4250197125482
  • 0,571 kg
€21.98 *
With the “Eisbaer” Quick-Connect Extension Kit, expanding an “Eisbaer” or “Eiswolf”... more
With the “Eisbaer” Quick-Connect Extension Kit, expanding an “Eisbaer” or “Eiswolf” GPX-Pro cooler loop with additional components is simple. For example, it’s easy to add another radiator, an additional cooler or any other components.
The kit consists of two 32cm-long hoses in 11/8 format, encased in anti-kink springs. This prevents bending in the hoses, and thereby prevents interruptions to the flow of water. Safety is our top priority.
Two ends have 90° angled pieces, pre-installed on the hoses. The only thing you need to do is screw these into the corresponding G1/4” threads. On the other end are the ends of two quick-release safety locks from the Alphacool HF series, just like the ones found on the “Eisbaer” or “Eiswolf”. That means all you have to do is open the quick-release locks on the “Eisbaer” or “Eiswolf” and screw them together with the corresponding parts in this kit and an additional product for extension, and your loop is complete - after it’s been filled, of course. For that, this kit includes a squeeze bottle with 250mL of osmosis filtered water. With the squeeze bottle, the loop can easily be filled at the designated spots. On the “Eisbaer”, for example, this would be the fill port on the “Eisbaer” cooler.
Technical Details:
  • tubing length: 32cm
  • Material Quick Connector: Nylon
  • Colour: Black
  • G1/4" Threads
  • tubing size: 11/8mm
  • Pre-filled: 250ml osmosis water
  • Alphacool Eisbaer Quick-Connect Extension Kit
Notice for expansion:
Please take care not to mix up the IN and OUT ports. On the “Eisbaer”, the “outlet” is marked in “red” and the “inlet” in “blue”. On the components to be connected, it is the opposite. The coupling with the “blue” marking denotes the “outlet” and the coupling with the “red” marking is the “inlet”. This is important as in many coolers the flow direction is crucial for optimal cooling performance.
WZS Spritzflasche 1000ml PE-LD
€6.19 *
Alphacool MCX seal plug - black 10 pcs kit
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
WAGZ Alphacool NexXxos Abstandshalter für GPX Wasserkühler
Alphacool NexXxos spacer for GPX water block
€1.98 *
KOI Alphacool Eisbaer 280 CPU - Black
Alphacool Eisbaer 280 CPU - black
€124.98 *
KOI Alphacool Eisbaer 360 CPU - Black
€136.98 *
ANZ Alphacool Eiszapfen Verschlussschraube V.2 G1/4 - Deep Black
Alphacool Eiszapfen screw plug V.2 G1/4 - deep black
€3.98 *
WAC Alphacool Eisbaer (Solo) - 2600rpm - Chrome
Alphacool Eisbaer (Solo) - 2600rpm - chrome
€69.98 *
Content 1 Gramm (€8,980.00 * / 1000 Gramm)
KOI Alphacool Eisbaer LT360 CPU - Black
Alphacool Eisbaer LT360 CPU - black
€119.98 *
ROH Alphacool Eisbaer GPX Extension Set (Schlauch und Anschlüsse)
Alphacool Eisbaer GPX Extension Set (tubes and fittings)
€13.19 *
AGB Alphacool Repack Dual Bayres 5,25" - Rev.2
€29.98 * €45.99 *
WAC Alphacool Eisbaer Pro ES (Solo) Full Black
€72.99 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3070TI AMP Holo mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3070TI AMP Holo with Backplate
€79.03 * €149.98 *
PUM Alphacool Rise Flat Reservoir DDC mit DDC310 Pumpe
Alphacool Rise Flat Reservoir DDC with DDC310 pump
€129.98 * €149.98 *
WÄM Alphacool Rise Wärmeleitpaste 6W/mK 4g
Alphacool Rise Thermal grease 6W/mK 4g
€5.99 * €8.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800XT/6900XT MERC 319 mit Backplate
Eisblock Aurora Acryl GPX-A Radeon RX 6800XT/6900XT MERC 319 with Backplate
€74.62 * €139.74 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 TUF mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 TUF with Backplate
€89.99 * €159.97 *
KOI Alphacool Eisbaer Pro Aurora 420 CPU AIO
€229.98 *
KOI Alphacool Eisbaer Pro Aurora 360 CPU AIO
€199.98 *
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
Alphacool Eisbaer TPV Extension kit (tube and fittings)
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
L14 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (140x140x25mm)
€12.98 * €19.98 *
WAGZ Alphacool Eisblock Aurora Terminal Abdeckung - Acetal
Alphacool Eisblock Aurora Terminal cover - Acetal
WAC Alphacool Eisbaer Aurora (Solo) - Digital RGB
€74.98 *
Alphacool HF compression Fitting TPV - 12,7/7,6mm Straight - Black - 6pcs Kit
KOI Alphacool Eisbaer Aurora 420 CPU - Digital RGB
€189.98 *
L12 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (120x120x25mm)
€9.98 * €12.98 *
KOI Alphacool Eisbaer Aurora LT360 CPU AIO Digital RGB
€159.98 *
KOI Alphacool Eisbaer LT240 CPU - Black
Alphacool Eisbaer LT240 CPU - black
€109.98 *
