Alphacool Eiswasser Crystal Yellow UV-active premixed coolant 1000ml
- Article no.: 18542
- EAN: 4250197185424
- Weight: 1,1 kg
Alphacool Eiswasser gives your water cooling system an extra visual highlight with great cooling performance and a long lifespan.
Technical data | |
Content | 1000ml |
Specification | Ready mix |
Color | yellow |
UV ink | yellow |
Manufacturer | Alphacool |
Inhalt: | 1000ml |
Spezifikation: | Fertiggemisch |
Farbe: | gelb |
UV-Farbe: | gelb |
Liefertermin: in 4 - 5 Tagen
Liefertermin: in 7 - 8 Wochen
