Alphacool Eiszyklon Aurora LUX PRO Digital RGB (140x140x25mm)
  • 24807
  • 4250197136167
  • 0,231 kg
€7.98 * €11.98 * (33.39% Saved)
LED Alphacool Aurora Eiscontrol Addressable RGB Controller - Black
€15.98*
KAB Alphacool Digital RGB LED Y-cable 3-way with JST connector - black 60cm
€7.98*
KAB Alphacool Eis-Matrix II - Adapter 5-Pin to PWM + 5V Digital RGB (3pcs) each 20cm EOL
€4.47*
You may have already seen the Alphacool Eiszyklon Aurora LUX Pro fan on the Alphacool Eisbaer... more
You may have already seen the Alphacool Eiszyklon Aurora LUX Pro fan on the Alphacool Eisbaer Aurora series. It offers a wide control range as well as outstanding digital RGB LED lighting. The individually controllable 5V aRGB LEDs paired with the special design of the fan frame create unique effects.
Ingenious Lighting
The frame is equipped with digital addressable 5V RGB LEDs which illuminate the whole frame. The frame is not completely transparent, but the illumination is done through narrow slits in four places. On the upper side there are two rows of these slits. Each narrow frame runs along the inside and outside of the frame. This creates a unique illumination which looks very noble. Thanks to the recessed light diffusers the light is distributed evenly. This means that Individual LEDs are no longer visible.
Wide Control Range and Silent
The fan can be controlled from 600 to 1500 rpm via the 4-pin PWM connector. At 600 rpm the fan is almost silent, but still offers a good airflow rate as well as a high static pressure. Therefore, the fan can also be used very well on radiators for a water cooling system. Thanks to the high airflow, the fan is also ideal for ventilating a case. Decouplers are also found directly on the frame. The soft foam padding reduces the transmission of vibrations to the case. A further plus point for the silent capability of the fan.
Connections?
The fan is controlled via a 4-pin PWM connector. The cable is 50 cm long. This allows the fan to be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
Speed600-1500 RPM
Static pressure1,6 mm/H2O
Air flow rate71 m³/h
BearingsHydraulic
Fan connector4-Pin PWM
Quantity Digital aRGB LED16
Dimensions140 x 140 x 25 mm
Net weight180 g
Max working temperature60 °C
Power consumption2 W
Noise12-38 dB(A)
MTBF50.000h
€1.48 *
€3.78 *
€2.78 *
€2.48 *
€5.68 *
€3.47 *
€2.68 *
€5.99 *
Delivery date: in 5 - 6 days
€37.98 *
7%
51%
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
85%
€1.98 * €12.98 *
ANS Alphacool HT 13mm HardTube Anschraubtülle G1/4 - gerändelt - Deep Black Sixpack PHT EOL
Alphacool HT 13mm HardTube screw-on nozzle G1/4 - knurled - Deep Black Sixpack
