Alphacool replacement O-rings for Eisblock GPX-A 11944
![WAGZ Alphacool Ersatz O-Ringe für Eisblock GPX-A 11944](https://aquatuning.shop-cdn.com/media/image/c3/21/8f/1023057_153Bl54sA4ssyL_600x600..jpg)
- Article no.: 13354
- EAN: 4250197133548
- Weight: 0,013 kg
- Available:
Alphacool replacement O-rings for Eisblock GPX and Eiswolf 2. The set contains all O-rings needed for complete replacement in the following cooler(s) and AIO(s)*:
- item no. 11944, Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT/6900XT Reference with Backplate
- item no. 14423, Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT/6900 Reference Design with Backplate
(* if AIO is available)
![WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT/6900XT Reference mit Backplate EOL](https://aquatuning.shop-cdn.com/media/image/96/67/ec/1020774_1qKtQ0pgrw629n_200x200..jpg)
![KOI Alphacool Eiswolf 2 AIO - 360mm Radeon RX 6800/6800XT/6900 Reference Design mit Backplate](https://aquatuning.shop-cdn.com/media/image/f5/38/87/1020901_19QhdrlURsetwX_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - Ultra Clear 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/2b/ba/c9/1019548_1KA2xVJXgo7bKU_200x200..jpg)
![PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe](https://aquatuning.shop-cdn.com/media/image/84/84/25/1019164_1VI1uAaOVHpQG4_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
![ANS Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/96/8f/92/1017628_1I8SPw61DVIHyS_200x200..jpg)
![SZ Alphacool Silicon Bending Insert 30cm für ID 1/2" / 13mm HardTubes - Blau](https://aquatuning.shop-cdn.com/media/image/77/3c/c1/1013191_1LMhcSPMAOJQ6p_200x200..jpg)
![WAZ Alphacool Eiswasser Crystal Yellow UV-aktiv Fertiggemisch 1000ml](https://aquatuning.shop-cdn.com/media/image/09/e7/1e/1012559_1lXzZrR2CAgYUA_200x200..jpg)
![S16 Alphacool Eisrohr 16/13mm PETG HardTube 60cm - 4er Set (240cm)](https://aquatuning.shop-cdn.com/media/image/06/39/a7/1012519_1cBhSstQBYWqtP_200x200..jpg)
![ANS Alphacool Eiszapfen 13/10mm Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/6d/20/21/1011157_1JKkyBLDJ9jN0Y_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/01/87/07/87273_1dl3tTrqVwGNmt_200x200..jpg)
