- Article no.: 17477
- EAN: 4250197174770
- Weight: 0,246 kg
*1The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
| Technical Data | |
| Dimension (D x L) | 26mm x 23mm |
| Material | Brass |
| Thread | G1/4" |
| Thread lenght | 5mm |
| HardTube size | 16mm |
| Compatibility | PETG, acrylic, brass and glass tubes |
| Weight | 4,2g |
