Alphacool Eisfluegel flow indicator black G1/4 IG - acrylic
  • 17366
  • 4250197173667
  • 0,046 kg
18546 Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
€12.98*
18548 Alphacool Eiswasser Crystal Clear UV-active premixed coolant 1000ml
€12.98*
Alphacool Eisflügel: The flow indicator with added value! Water cooling in a computer always... more
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
  • Dimensions: 69.5 x 41 x 17mm
  • pressure load up to 2 bar, max.
  • Connection: for all G1/4" connections
  • Material: ABS
Scope of delivery
  • 1x Alphacool Eisfluegel flow indicator black G1/4 IG - acrylic
Delivery date: in 5 - 6 weeks
€27.98 *
