Phobya 4Pin Molex Stromverlängerung - Schwarz 30cm
- Article no.: KAB
- EAN: 4049469100759
- Weight: 0,016 kg
Extension cable for connection of a 4-Pin Molex fan (CPU fan, case fan etc.) to a PSU connector or other fan connector (4-Pin Molex), approx. 32cm long.
Sleeving:
The idea behind these cables:
Technical specifications:
Connector: 4-pin plug to 4-Pin socket
Length: 30 cm
Colour: black sleeve, black heatshrink, black connectors
Extent of delivery:
1x Phobya 4Pin Molex power extension 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Extremehardware (it.)
1. Seite: | 1x 4Pin |
Hersteller: | Phobya |
Sleeving: | schwarz |
Bauform: | Verlängerung |
2. Seite: | 1x 4Pin |
Liefertermin: in 2 - 3 Wochen
