Phobya Y-cable 4Pin PWM 2x 4Pin PWM - Black 10cm
- Article no.: LK
- EAN: 4049469175573
- Weight: 0,01 kg
An adapter from one PWM connector (4Pin) to 2x PWM (4Pin).
Since controlling and switching PWM fans via the mainboard is much more cost-effective than using a fan controller, this cable is ideal. This cable can be used to increase the small number of mainboard slots for this type of fan.
The adapter is supplied in a simple black. The cables are shielded with a matching sheath made of flex sleeves. It offers additional protection against abrasion. This increases the service life of the cables considerably. The ends near the connectors have been provided with shrink tubing to create a clean transition.
Sleeve:
Sets:
Technical details:
Connections:
1x PWM female connector
2x PWM male connector
Colour: black sleeve, black connectors, black shrink tubing
Dimensions: complete 10cm
RoHS compliant
1x Phobya Y-cable 4Pin to 2x 4Pin PWM 10cm - Black
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 2x 4Pin PWM |
