Phobya 4Pin PWM extension 60cm
- Article no.: LK
- EAN: 4049469100087
- Weight: 0,01 kg
An extension of a PWM connector (4 pin).
Since controlling and switching PWM fans via the mainboard is much more cost-effective than using a fan controller, this cable is ideal.
The extension cable is delivered without a sleeve, so everyone is free to design it.
Technical data:
Length: 60cm
Connection type: 4 pin PWM
1x Phobya 4Pin PWM extension 60cm
Note: Please note the difference between a 4 pin power connector (Molex) and a 4 pin fan connector (PWM).
This product was tested for you:
Aqua info
Tech Review
Sleeving: | ohne |
1. Seite: | 1x 4Pin PWM |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin PWM |
Bauform: | Verlängerung |
Liefertermin: in 2 - 3 Tagen
Liefertermin: in 6 - 7 Wochen
