Phobya Adapter 3Pin (female) to 4Pin PWM (male) - Black 30cm
- Article no.: LK
- EAN: 4049469124380
- Weight: 0,008 kg
This is an adapter from a 3pin female to a 4pin PWM male.
This cable can be used to connect your 3-pin fans to your power supply or to the fan controller as usual. Unfortunately, the adapter does not transmit any speed signals, but the fan speed can still be controlled by the power supply, which is how most fan controllers control the fans.
Sleeve:
Sets:
Technical data:
Length: 30cm
Color: black
Connection type: 3 pin
1x Phobya adapter 3Pin (female) to 4Pin PWM (male) 30cm - black
Bauform: | Adapter |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin |
Liefertermin: in 2 - 3 Tagen
Liefertermin: in 6 - 7 Wochen
