Alphacool Core Geforce RTX 5080 Prime with Backplate
- Article no.: 14763
- EAN: 4250197147637
- Weight: 1,554 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Asus Prime GeForce RTX 5070 Ti OC, PRIME-RTX5070TI-O16G, 16GB GDDR7 (90YV0MF0-M0NA00)
- Asus Prime GeForce RTX 5080 OC, PRIME-RTX5080-O16G, 16GB GDDR7 (90YV0LX0-M0NA00)
- Asus Prime GeForce RTX 5080, PRIME-RTX5080-16G, 16GB GDDR7
| Technical data cooler | |
| Dimensions total (L x W x H) | 220x 140,60 x 34,19mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 10 |
| Color | transparent |
| Dimensions (L x W x H) | 220 x 112,10 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
