Alphacool Core Geforce RTX 5090 EPIC-X with Backplate
  • 14739
  • 4250197147392
  • 1,754 kg
€219.98 *
€125.98*
€35.98*
€37.98*
- PNY GeForce RTX™ 5090 ARGB EPIC-X RGB™ Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5090 ARGB EPIC-X RGB™ Triple Fan GPU
- PNY GeForce RTX™ 5090 Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5090 Triple Fan GPU
Technical data cooler
Dimensions total (L x W x H)218,40 x 148,57 x 34,38mm
Material cooler topAcrylic
Material terminalAcetal
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs9
Colortransparent
Technical data backplate
Dimensions (L x W x H)218,40 x 120,00 x 6,00mm
Thick backplate without spacers3mm
MaterialAluminium
WAC Alphacool Core 1 Silver
Alphacool extension JST aRGB 3-pin to 3-pin 15cm
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
€5.28 *
€2.28 *
€1.98 *
€37.98 *
€6.99 *
Alphacool D-RAM module (for Alphacool D-RAM cooler) - black 2 pieces
Content 2 Stück (€11.99 * / 1 Stück)
€23.98 *
