Alphacool ES U-shape RAM Water Cooler 8-Bay Set
  • 17646
  • 4250197176460
  • 0,62 kg
€157.98 *
€19.98*
€31.98*
€356.98*
Alphacool ES Distro Plate C5
€57.98*
€79.98*
17635 Alphacool ES deionized water (ultrapure water) 5000ml
€69.98*
The Alphacool ES U-shape RAM water cooler has been specifically designed to meet the high... more
The Alphacool ES U-shape RAM water cooler has been specifically designed to meet the high demands of powerful memory modules in server and workstation systems. Up to 8 RAM modules can be efficiently cooled with the U-shaped water cooler. Its flat design and versatile connection options make it easy to install in almost any server or workstation case.
Reliable Cooling Performance
Modern RAM modules are becoming more powerful, generating increasing amounts of waste heat. To avoid loss of performance, reliable cooling is essential. This cooler meets that requirement. As is usual with Alphacool products, this water cooler is made entirely of copper to ensure maximum cooling performance.
Easy Installation
Installation has been made as simple as possible. The RAM modules are enclosed by two nickel-plated copper sheet plates and installed on the motherboard. Then, the water cooler is routed over the RAM modules. The input and output connections to the front and sides allow for flexible integration into the water cooling loop.
Note: This cooler is only compatible with single-row RAM modules, see image or manual.
Dimensions (L x W x H)185,26 x 62,46 x 21,50mm
MaterialCopper
Weight (water cooler solo)240g
Total weight (with RAM cooling plates)530g
Covered RAM SlotsUp to 8
Gap between cooling channels5,47mm
Pressure tested8 bar
Connections2x G1/4“ In | 2x G1/4“ Out
Warranty: 2 years
€6.49 * €8.98 *
€83.98 *
44%
Alphacool AGB Universal Mount Clip-On 50mm - Black 2 pieces
Content 2 Stück (€2.24 * / 1 Stück)
€4.48 * €7.98 *
ceramic axis Eheim 1046/48
€7.98 * €11.44 *
