Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
- Article no.: 12454
- EAN: 4250197124546
- Weight: 0,37 kg
Fastening: | Slightly adhesive |
Thickness: | 0,5mm |
Surface dimensions: | 120 x 20mm |
Thermal conductivity: | 11W/mk |
