AMD 7000 Series Thermal Pad Replacement set
  • 1025721
  • 4049469341282
  • 0,089 kg
Pads included: 1mm 14x 8x8mm 1x 8x115mm 1x 8x87mm 3x 15x56mm 3mm 1x 8x100mm 1x... more
Pads included:
1mm
14x 8x8mm
1x 8x115mm
1x 8x87mm
3x 15x56mm
3mm
1x 8x100mm
1x 8x81mm
1x 45x45mm (hole in the middle)
3x 15x60mm
1x 15x80mm
1x 15x105mm
Made in: China
€6.49 * €8.98 *
WÄM AMD 6000 Series Thermal Pad Replacement set
WACZ Alphacool Core AM5 Performance Kit
€21.98 *
Delivery date: in 6 - 7 weeks
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 60cm white
Content 60 Zentimeter (€8.30 * / 100 Zentimeter)
€4.98 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm white
€3.78 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 60cm white
€3.88 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 30cm white
€2.98 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 15cm white
€2.58 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 60cm
€6.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 15cm
€5.68 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 15cm
€4.48 *
Alphacool Y-Splitter aRGB 3-Pin to 3x 3-Pin 60cm
€5.99 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 60cm
€4.68 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 30cm
€3.97 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
€2.98 *
€2.78 *
€2.58 *
€1.68 *
€1.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 60cm
€2.48 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
€2.28 *
Alphacool fan cable 3-Pin to 3-Pin extension 15cm
€1.98 *
€4.38 *
€29.98 *
24%
AGB Alphacool Rise Flat Reservoir D5
€79.98 * €104.98 *
Content 2 Stück (€12.99 * / 1 Stück)
€25.98 *
