Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x3mm yellow marked PE Bag (24 pieces)
  • 12195
  • 4250197121958
  • 0,033 kg
€6.29 *
Content: 54 cm² (€0.12 * / 1 cm²)
Area of application:
  • Graphics card ram cooler
  • Mainboard voltage converter
  • North and/or Southbridge thanks to the excellent thermal conductivity
  • Color: grey
  • Dimensions (L x W x H): 15 x 15 x 3mm
  • Thermal conductivity: 3W/mk
  • electrically non-conductive
Scope of delivery
  • 24x Alphacool thermal pad for NexXxoS GPX
Fastening: Slightly adhesive
Thickness: 3,0mm
Surface dimensions: 30 x 30mm
Thermal conductivity: 3,0W/mk
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
€21.98 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x0.5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x2mm
€24.98 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1mm
Alphacool Core thermal pad Soft 6.2W/mk 100x100x1mm
Content 100 cm² (€0.17 * / 1 cm²)
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
€1.89 *
RAD Alphacool NexXxoS HPE-30 Full Copper 480mm Radiator
€129.98 *
Delivery date: in 5 - 6 days
€29.98 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
Alphacool Rise Ultra Soft thermal pad 7W/mk 100x100x0.5mm
11%
€15.98 * €17.98 *
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 3m (9.8ft) retail box 300cm
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
