Alphacool Ice Layer Thermal Pad - 11W/mK 120x20x0.5mm - 2 pieces
  • 12454
  • 4250197124546
  • 0,37 kg
Content: 48 cm² (€0.31 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 0,5mm
Surface dimensions: 120 x 20mm
Thermal conductivity: 11W/mk
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück
€21.98 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück
Content 48 cm² (€0.60 * / 1 cm²)
€28.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
€29.98 *
Alphacool HF screw plug G1/4 - Deep Black
€1.68 *
Liefertermin: in 8 - 9 Wochen
ZSO Alphacool Becher schwarz
Alphacool mug black
Alphacool Core thermal pad Soft 9W/mk 120x20x0.5mm
Content 24 cm² (€0.33 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.81 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Core thermal pad Soft 6.2W/mk 40x40x0.5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
€1.89 *
17%
S16 Alphacool Carbon HardTube 16mm 4x 80cm
Content 80 Zentimeter (€43.71 * / 100 Zentimeter)
€34.97 * €42.00 *
WAH Alphacool HDX Apex Acetal M.2 2280 SSD Kühler
Alphacool HDX Apex Acetal M.2 2280 SSD Cooler
€30.00 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
Liefertermin: in 2 - 3 Wochen
17%
€14.98 * €17.98 *
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
