Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
  • 12196
  • 4250197121965
  • 0,025 kg
€3.78 *
Content: 36 cm² (€0.11 * / 1 cm²)
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 30 x 30 x 3mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
4x Alphacool thermal pad for NexXxoS GPX
Fastening: Slightly adhesive
Thickness: 1,5mm
Surface dimensions: 30 x 30mm
Thermal conductivity: 3,0W/mk
WÄM Alphacool Wärmeleitklebepad doppelseitig 100x100x0,5mm EOL
Alphacool thermal adhesive pad double-sided 100x100x0.5mm
Content 100 cm² (€0.04 * / 1 cm²)
€3.97 *
€1.19 *
WÄM Alphacool Wärmeleitklebepad doppelseitig 120x20x0,5mm EOL
Alphacool thermal adhesive pad double-sided 120x20x0.5mm
Content 24 cm² (€0.10 * / 1 cm²)
€2.28 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
€21.98 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x0.5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x2mm
€24.98 *
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
22%
€46.98 * €59.98 *
€1.89 *
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.40 * / 1 cm²)
€29.98 *
Alphacool Rise Ultra Soft thermal pad 7W/mk 100x100x0.5mm
11%
€15.98 * €17.98 *
Alphacool Silicon Bending Insert 150cm for ID 1/2" / 13mm HardTubes - Blue
Content 150 Zentimeter (€11.32 * / 100 Zentimeter)
€6.99 *
