  • 13096
  • 4250197130967
  • 0,03 kg
€46.98 * €59.98 * (21.67% Saved)
Content: 20 Gramm (€2,349.00 * / 1000 Gramm)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
13013 Alphacool Rise Ultra Soft thermal pad 7W/mk 50x50x3mm
€7.98*
13014 Alphacool Rise Ultra Soft thermal pad 7W/mk 50x50x2mm
€6.99*
13098 Alphacool Apex Thermal grease 100g
€122.97*
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum... more
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 20g container with screw cap. The amount of thermal paste is sufficient for several applications and can be stored in the container protected from drying out. In addition, Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Volatilization Rate (24H@200°C)%less than 0.5
Density (g/cc)3.2 (Test method ASTM D792)
Viscosity (mPa.s)150~200*10³ (Test method ASTM D2196)
Continuous Using Temperature (°C)-40°C to 120°C
Breakdown Voltage (V/mil)250 (Test method ASTM D149)
Thermal Impedance (°C in 2/W)0.1 +/- 0.01 (Test method ASTM D5470)
Max. working pressure (psi)40
Colorgray
Quantity20g
Safety notes
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
Alphacool Silver Grease 0.5g
€1.19 *
€4.97 *
20%
€3.97 * €4.97 *
21%
€33.97 * €42.98 *
63%
€1.58 * €4.28 *
€6.99 *
€33.98 *
€6.49 * €8.98 *
6%
€16.98 * €17.98 *
Leak Testing Tool incl. Pump
€36.98 *
€26.98 *
SZ Schlauchabschneider
hose cutter
€6.29 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x0,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 120x20x0,5mm
Content 24 cm² (€0.62 * / 1 cm²)
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x0,5mm
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x0,5mm
Content 100 cm² (€0.60 * / 1 cm²)
€59.98 *
S16 Alphacool EPDM Tube 16/10 - Black 1m (3,28ft) Retailbox
