Alphacool replacement UV cathode for Eisbecher Helix 250mm
  • AGZ
  • 4250197153485
  • 0,034 kg
  • There are more than 5 units available
Replacement UV cathode for ice cream bowl Helix 250mm Simply unscrew the old cathode from... more
Simply unscrew the old cathode from the lid of the ice cream bowl Helix and screw the new cathode back in --> Done.
Important: The replacement UV cathode is only compatible with the Alphacool Eisbecher Helix. It is not compatible with any other Alphacool Eisbecher variants!
Alphacool Aurora LED Flexible Light - Digital RGB 30cm
Content 30 Zentimeter (€53.27 * / 100 Zentimeter)
LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 30cm
Phobya 4Pin PWM Male to Male - Black 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
56%
S13 Alphacool HardTube 13/10mm Acryl (PMMA) Klar UV-Blau 60cm - 4er Set (240cm)
Alphacool HardTube 13/10mm Acrylic (PMMA) Clear UV-Blue 60cm - Set of 4 (240cm)
Content 240 Zentimeter (€3.00 * / 100 Zentimeter)
€7.19 * €16.29 *
43%
Adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x0,5mm
Alphacool Apex thermal pad Soft 18W/mk 120x20x0.5mm
Content 24 cm² (€0.92 * / 1 cm²)
€21.98 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 60cm
€6.99 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
Alphacool Y-Splitter 3-Pin to 3x 3-Pin 15cm
€2.48 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 30cm
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Content 6 Stück (€2.16 * / 1 Stück)
Content 24 Stück (€0.17 * / 1 Stück)
€3.98 *
€6.28 *
€29.98 *
Alphacool M3 spacer 34mm
€3.48 *
Content 10 Stück (€0.17 * / 1 Stück)
€1.68 *
S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - UV Grün 3m (9,8ft) Retailbox 300cm
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV Green 3m (9.8ft) Retailbox 300cm
