Alphacool Core 140mm Reservoir with VPP/D5 Pump
  • 13889
  • 4250197138895
  • 1,34 kg
€169.98 *
€18.98*
LED Alphacool Aurora Eiscontrol Addressable RGB Controller - Black
€15.98*
€36.99*
L12 Alphacool Apex Stealth Metal Power Fan 3000rpm Matt Black (120x120x25mm)
€29.98*
The Alphacool Core Reservoir not only looks sleek with its aRGB lighting, but can also be used... more
The Alphacool Core Reservoir not only looks sleek with its aRGB lighting, but can also be used flexibly thanks to its compact size. The reservoir is made entirely of acrylic. The installation of a D5 or VPP pump is required for operation. Due to its compact design, the Core Reservior also fits into small cases.
Core Design
A key element of Alphacool's Core Design series are the chrome-plated G1/4" connections made of brass. In the Core Reservoir, the connections are recessed rather than screwed into a thread, bypassing the problem of possible leaks due to cracking from the direct screwing of the connections into the acrylic. The connections are in two parts, fitted with an O-ring and counter each other when mounted in the acrylic. This not only ensures absolute sealing of each connection, but also allows for the clear and functional appearance of the Alphacool Core Design series.
Easy installation
With the included Core Push Mounting kit, the Core Reservoir can be mounted on the case or on a radiator. The metal pins are attached to the radiator or case panel and the matching female sleeves are attached to the Reservoir (see manual). In the next installation step, the Reservoir is simply and tool-free pushed onto the pins. Alphacool's Push-Mounting allows for a secure fit of the reservoir on the case panel or on the radiator and allows for easy disassembly for maintenance or expansion projects.
Gamechanger
The Core Reservior is small and compact. This makes the reservoir ideal for custom water loops. An additional drain port is located on the side, allowing for easy and uncomplicated draining of the Reservoir.
High-quality material selection & brilliant lighting
Alphacool's Core Reservoir is made of high-quality acrylic glass, allowing for an unobstructed view of the coolant and brilliant illumination by the built-in digital addressable aRGB LEDs. The lighting can be controlled via a digital aRGB header on the motherboard or optionally through Alphacool's Aurora Eiscontrol aRGB controller (item number: 15360).
Dimensions (L x W x H)140.00 x 145.00 x 62.00mm
Volume (reservoir)approx. 130ml
MaterialAcryl
Pump compatibilityD5/VPP
Threads3x G1/4“ inner thread / 1x drain port
Pressure tested0.8 Bar
Quantity digital aRGB LEDs5
Voltage digital aRGB LEDs5V
Power connection digital aRGB LEDs3-Pin JST + 3-Pin 5V
Weight1120g
Colortransparent
Technical data pump
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Material: Acryl
Anschluss: G1/4" Innengewinde
Pumpenkompatibilität: für 1x D5
Pumpe vorinstalliert: Ja
Farbe: transparent
Abmessungen: 140.00 x 145.00 x 62.00mm
Volumen: 130ml
AGB Alphacool Cape Corp Coolplex Pro 25 LT
and Conditions Alphacool Cape Corp Coolplex Pro 25 LT
€34.98 *
45%
AGB Alphacool Eisbecher 250mm Acryl Ausgleichsbehälter EOL
and Conditions Alphacool Eisbecher 250mm Acrylic Expansion Tank
€29.99 * €54.99 *
Liefertermin: in 2 - 3 Wochen
6%
AGB Alphacool Eisbecher Lite 250mm Acetal Ausgleichsbehälter EOL
Alphacool Eisbecher Lite 250mm Acetal Reservoir
€29.99 * €31.99 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
WACZ Alphacool Core AM5 Performance Kit
€99.98 *
Content 6 Stück (€6.17 * / 1 Stück)
€36.99 *
Alphacool Ice Water Crystal Red Ready Mix 1000ml
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pieces
€3.98 *
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
RAD Alphacool NexXxoS ST30 Full Copper 420mm Radiator
€85.98 *
