and Conditions Alphacool Eisbecher 250mm Acrylic Expansion Tank
  • 15194
  • 4250197151948
  • 0,768 kg
€29.99 * €54.99 * (45.46% Saved)
RAB Alphacool 120/140mm bracket for Alphacool Eisbecher - 2 pieces
€11.98*
A pipe reinvented The ice cream bowl series consists of 20 different expansion tanks that... more
A pipe reinvented
The ice cream bowl series consists of 20 different expansion tanks that differ in the type of application, size and appearance. Among these, there are ten expansion tanks that are made of 99% acrylic glass - that's unique! The main difference, however, is the function of the different bases.
Essential components
Bubble Down
This is located at the very bottom of the expansion tank and effectively prevents the formation of suction and whirlpools, thereby preventing the suction of air bubbles.
Lighttower riser tube
The so-called "light tower" effect creates a visual experience in any water cooler. In the ice cream cups, this was used both from below and from above. The water is led up or down through the riser tube and sprays through eight evenly distributed holes at the end of the tube onto the inner wall of the container. This interesting-looking water feature is the so-called light tower effect.
Stand
The feet known from ice sheets are also used here and give each combination a firm footing.
Brackets
Two brackets are installed above and below the pipe for fastening in the housing. These brackets have holes spaced apart by a 120mm or 140mm fan. However, if the container is not to be mounted on fan slots, the brackets can be reduced to the width of the container and there are three M4 threads per bracket available for fastening. Even if the brackets are not used at all, they can be easily removed. This bracket can be found on all 20 containers.
Lighting module
The lighting modules are made of acrylic glass and enable lighting with a 5mm LED. The modules can be screwed into all 1/4" openings. They are used in the lid and sometimes in the bases of the containers. This allows unique lighting effects to be created.
material
All versions of the container are available in acetal and acrylic, so there is something for everyone.
Sizes
All containers are available in two different sizes: the 150mm version and the 10cm larger 250mm version. Due to the size, the smaller container only has one riser tube coming from the bottom. The larger container even has two, one coming from the bottom and one from the top.
The ice cream sundae
For those who prefer to operate their pump separately, two other versions are available. The Bubble Down is used here and, depending on the size, one or two riser tubes for the light tower effect and two lighting modules from above and below. In addition, three additional LED holes were drilled into the base for the acrylic version to increase the luminosity. The inlet and outlet for the coolant are each present twice - once from the side and once from below.
The scope of delivery includes:
  • 8x M4x8mm screw
  • 4x M4 nut
  • 2x G1/4" screw plug
  • 1x hexagon key 2.5mm
Dimensions 250mm Version:
  • Dimensions including bracket (LxWxD): 251 x 136 x 79.5mm
  • Dimensions without bracket (LxW): 251 x 60mm
  • Acrylic tube diameter: 60mm
  • Capacity: 360ml
Assembly instructions
Download 3D file (.stp)
Notice:
In order to use the intake from the top, a G1/4” extension piece is necessary (article 1011183-1011186), since the screw thread is embedded a few mm into the lid and many compression fittings will not be able to be screwed in.
Color: transparent;
Fillport: G1/4" internal thread
Material: Acryl;
Dimensions: 60 x 60 x 250mm
Connection: G1/4" internal thread
Pump pre-installed: No
Number of connections: 6
Pump compatibility: For flow pumps
Container type: Tube container 60mm
LED holes: Available (for 5mm LEDs)
€11.98 *
€5.48 *
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - Ultra Clear 3m (9.8ft) retail box 300cm
63%
€1.58 * €4.28 *
€99.98 *
Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - White Sixpack
€33.98 *
