Alphacool NexXxoS HPE-30 Full Copper 560mm Radiator
  • 14471
  • 4250197144711
  • 1,546 kg
€173.98 *
€62.98*
€19.98*
€18.98*
€31.98*
12948 Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€59.98*
13056 Alphacool Eisblock Aurora Acryl GPX-N RTX 3090TI Founders Edition with Backplate
€49.99*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H596,5 x 144 x 30mm (+/- 3%)
Quantity of cooling channels16
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length)
Possible fan size140mm
Possible fan assembly4x one-sided / 8x both-sided
Thread size fan mountingM3
Pressure tested0,8 Bar
Fin density18 FPI
Weight1225g
Warranty: 10 years
PUM Alphacool Core Flat Reservoir 240 Rechts mit VPP/D5 Apex PWM Pumpe
Alphacool Core Flat Reservoir 240 Right with VPP Apex Pump
€209.98 *
Alphacool fan cable 4-pin to 4-pin extension 30cm white
€2.58 *
S16 Alphacool EPDM Tube 16/10 - Black 1m (3,28ft) Retailbox
€4.48 *
€3.47 *
€5.28 *
€34.98 *
