Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
  • 24774
  • 4250197247740
  • 0,004 kg
€0.99 * €9.94 * (90.04% Saved)
What is that?
Highlights
  • Made of aluminum
  • More stable than acrylic
  • For all common cable types
  • Four different colors
The Alphacool Eiskamm Alu is the optimal solution for laying your cables neatly and maintaining the best appearance. The Eiskamm cut from aluminum tubes are much more stable than acrylic versions. To avoid damage to the sleeve, all edges are rounded. Sharp edges that could cut into the sleeve are now a thing of the past. Of course, Alphacool offers all sizes for every cable type, from SATA cables to 8-pin and 24-pin ATX cables, including different colors.
  • Material: aluminum
  • Variant: X16
  • Dimensions: 37.1 x 9.5 x 2.5mm
  • Color: Silver
Scope of delivery
  • Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
Datasheet
Assembly instructions
€0.99 * €5.02 *
86%
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€0.99 * €6.96 *
€0.99 * €5.02 *
€0.99 * €5.02 *
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€0.99 * €5.02 *
90%
€0.99 * €9.94 *
85%
Alphacool Eiskamm Alu X12 - 4mm silver - 4 pieces
€0.99 * €6.56 *
Alphacool Eiskamm Alu X6 - 4mm silver - 4 pieces
€0.99 * €5.02 *
86%
€0.99 * €6.96 *
€0.99 * €4.89 *
88%
€0.99 * €8.00 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm EOL
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
85%
€0.99 * €6.56 *
€0.99 * €5.02 *
€0.99 * €5.02 *
52%
Hint!
€4.80 * €9.98 *
€1.89 *
€1.48 *
34%
Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
17%
16%
PUZ Alphacool Eisdecke D5 Acryl Aufsatz V.4 PHT EOL
Alphacool Eisdecke D5 Acrylic Top V.4
€41.98 * €49.98 *
