DREMEL® SC diamond cutting disc (EZ SpeedClic)
  • SC545
  • 8710364042883
  • 0,007 kg
€21.56 *
WZS DREMEL® SC diamond cutting disc (EZ SpeedClic)
€21.56*
A unique accessory that is particularly suitable for cutting/separating hard materials.... more
A unique accessory that is particularly suitable for cutting/separating hard materials. Examples: concrete, stone, porcelain, ceramics and epoxy resins. The diamond cutting disc ensures a clean cut, is extremely durable, does not break and retains its shape. Fast, easy, can be installed without tools.
Technical data:
Shaft diameter: 3.2mm
Working diameter: 38mm
Max. working depth: 11mm
Maximum speed: 20,000 rpm
Mandrel to be used: EZ SpeedClic mandrel (SC402)
S16 Alphacool HardTube 16/11mm 90° Borosilikatglas 20/40cm
Alphacool HardTube 16/11mm 90° borosilicate glass 20/40cm
Content 60 Zentimeter (€44.97 * / 100 Zentimeter)
€26.98 *
S16 Alphacool HardTube 16/11mm Borosilikatglas 60cm
Alphacool HardTube 16/11mm borosilicate glass 60cm
Content 60 Zentimeter (€23.30 * / 100 Zentimeter)
€21.98 *
Delivery date: in 7 - 8 weeks
ANS Alphacool Eiszapfen 16mm HardTube Anschraubtülle 90° drehbar G1/4 für Acryl/Messingrohre - 4pcs Set Deep Black
Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic/brass tubes - 4pcs
€33.98 *
Content 10 Stück (€0.17 * / 1 Stück)
€1.68 *
€34.98 *
€38.98 *
€3.98 *
Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€33.98 *
S16 Alphacool HardTube 16/11mm 90° Borosilikatglas 10/30cm
Alphacool HardTube 16/11mm 90° borosilicate glass 10/30cm
Content 40 Zentimeter (€62.45 * / 100 Zentimeter)
€24.98 *
WACZ Alphacool Core AM5 Performance Kit
€21.98 *
WAC Alphacool Core 1 White
€109.98 *
€21.98 *
ANS Alphacool Eiszapfen 16mm HardTube Anschraubtülle 90° drehbar G1/4 für Acryl/Messingrohre - 4pcs Set Chrome
€33.98 *
Content 24 Stück (€0.29 * / 1 Stück)
€6.99 *
