Alphacool Core Geforce RTX 4090 Founders Edition with Backplate
  • 13470
  • 4250197134705
  • 2,047 kg
€69.98 * €199.98 * (65.01% Saved)
€19.98*
€12.98*
€18.98*
€14.98*
14465 Alphacool Filling bottle Core 250ml
€4.98*
€241.98*
Alphacool's Core product series is characterized by high quality, outstanding performance and... more
- Nvidia GeForce RTX 4090 Founders Edition, 24GB GDDR6X (900-1G136-2530-000)
Technical data cooler
L x W x H208.87 x 148.69 x 32.33 mm
Material cooler topacrylic
Max working temperature60 °C
Pressure tested0.8 bar
Threads4 x G 1/4
Thickness cooler bottom11.3 mm
Thickness cooling fins0.4 mm
Distance cooling fins0.4 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5 V
Number of digital aRGB LEDs12
Technical data backplate
L x W x H208.87 x 125.69 x 5.76 mm
Materialaluminium
Awards & Videos
WAC Alphacool Core 1 Silver
€3.47 *
€27.98 *
