Alphacool Core Geforce RTX 4090 AMP with backplate
- Article no.: WAK
- EAN: 4250197134811
- Weight: 1,955 kg
- Manli GeForce RTX 4090 Gallardo, 24GB GDDR6X (N67540900M35300)
- Zotac Gaming GeForce RTX 4090 AMP Extreme AIRO, 24GB GDDR6X (ZT-D40900B-10P)
- Zotac Gaming GeForce RTX 4090 Trinity OC, 24GB GDDR6X (ZT-D40900J-10P)
- Zotac Gaming GeForce RTX 4090 Trinity, 24GB GDDR6X (ZT-D40900D-10P)
Technical data cooler | |
Dimensions (L x W x H) | 235,40 x 145,90 x 32,10mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 13 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 235,40 x 122,90 x 5mm |
Material | aluminium |
Color | black |
SLI kompatibel: | Ja |
Kühlertyp: | Komplettkühler |
Anschluss: | 4x G1/4" |
Material Deckel: | Acryl |
Abmessungen: | 235,40 x 145,90 x 32,10mm |
Hinweis: | Kompatibel bis 16/13mm gerade, Kompatibel bis 19/13mm gewinkelt |
Hardware Modell: | RTX 4090 |
Liefertermin: in 6 - 7 Tagen
