Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 - Deep Black
  • 17395
  • 4250197173957
  • 0,084 kg
€10.98 *
Design: 90° screw-on nozzle 16mm
This connector has a 1/4" thread on one side and is therefore compatible with 95% of all components. The other side is suitable for a 16mm acrylic and brass tube. In the middle, this connector is angled at 90° to avoid complicated hose routes. For maximum flexibility, the side with the thread can be rotated.
  • Material: Brass
  • Colour: Deep Black
dimension
  • Length: 45mm
  • Width: 29mm
Scope of delivery
  • 1x Alphacool Eiszapfen 16mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic brass tubes - Deep Black
Here you will find an interactive overview of all Alphacool connections.
€28.98 *
€39.98 *
€28.98 *
€26.98 *
€38.98 *
€1.78 *
Delivery date: in 2 - 3 weeks
