Alphacool Eiskoffer - Multi-Bending Feeder Large
  • 90354
  • 4250197136945
  • 0,168 kg
  • Currently there are 7 available
€26.98 *
Multi-bending feeder possible angles: 30°, 45°, 60°, 90° Large version Pipes with Ø... more
Large version
Pipes with Ø 13 or 12 mm are bent by a radius of 33.5 mm Pipes with Ø 16 mm are bent by a radius of 32 mm
Do not bend more than an added angle of 180° so that your pipe can be removed again when it has cooled down.
All bending guides and stops are designed for pipe diameters of 12 or 13 mm and 16 mm. The required guide is always aligned downwards.
manual
62%
hose cutter aluminum replacement blade 3-19mm
€0.99 * €2.59 *
€25.98 *
€28.98 *
€37.98 *
€26.98 *
€23.98 *
€20.98 *
