Alphacool Eisblock Aurora Geforce RTX 4090 GameRock + Phantom with Backplate
  • 13463
  • 4250197134637
  • 1,699 kg
  • Currently there are 9 available
€49.98 * €159.98 * (68.76% Saved)
€62.98*
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€16.98*
13009 Alphacool Subzero Thermal grease 20g
€33.97*
11999 Alphacool Eisbaer Aurora HPE Edition 360 CPU AIO
€188.98*
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics... more
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- Gainward GeForce RTX 4090 Phantom GS, 24GB GDDR6X (3413)
- Gainward GeForce RTX 4090 Phantom, 24GB GDDR6X (3390)
- Palit GeForce RTX 4090 GameRock OC, 24GB GDDR6X (NED4090S19SB-1020G)
- Palit GeForce RTX 4090 GameRock, 24GB GDDR6X (NED4090019SB-1020G)
Technical data cooler
L x W x H214.91 x 145.19 x 34.12 mm
Material cooler topacrylic
Max working temperature60 °C
Pressure tested0.8 bar
Threads4 x G 1/4
Thickness cooling fins0.4 mm
Distance cooling fins0.4 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5 V
Number of digital aRGB LEDs12
Technical data backplate
L x W x H214.91 x 120.69 x 6 mm
Materialaluminium
Awards & Videos
€27.98 *
€6.99 *
