Alphacool Core Geforce RTX 5080 Phoenix with Backplate
- Article no.: 10288
- EAN: 4250197102889
- Weight: 1,229 kg
- Gainward GeForce RTX™ 5070 Ti Phoenix
- Gainward GeForce RTX™ 5080 Phoenix
| Technical data cooler | |
| Dimensions total (L x W x H) | 182x 125,95 x 34,19mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 7 |
| Color | transparent |
| Dimensions (L x W x H) | 182 x 97,50 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
