Alphacool Core Geforce RTX 5080 Gaming Trio with backplate
  • 10276
  • 4250197102766
  • 1,466 kg
€219.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- MSI GeForce RTX™ 5070 Ti 16G GAMING TRIO OC
- MSI GeForce RTX™ 5070 Ti 16G GAMING TRIO OC PLUS (V531-058R)
- MSI GeForce RTX™ 5070 Ti 16G GAMING TRIO PLUS
- MSI GeForce RTX™ 5080 16G GAMING TRIO
- MSI GeForce RTX™ 5080 16G GAMING TRIO OC
- MSI GeForce RTX™ 5080 16G GAMING TRIO OC White
Technical data cooler
Dimensions total (L x W x H)180,50 x 151,07 x 34,20mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs8
Colortransparent
Technical data backplate
Dimensions (L x W x H)180,50 x 122,50 x 6,00mm
MaterialAluminium
€28.98 *
€37.98 *
WÄM Alphacool Apex Thermal Putty X1 30g
Content 30 Gramm (€999.33 * / 1000 Gramm)
€29.98 *
