Alphacool Core Geforce RTX 5090 Suprim + Vanguard + Gaming Trio with backplate
  • 10268
  • 4250197102681
  • 1,891 kg
€219.98 *
€19.98*
€37.98*
€125.98*
€35.98*
- MSI GeForce RTX™ 5090 32G GAMING TRIO OC
- MSI GeForce RTX™ 5090 32G SUPRIM LIQUID SOC (MS-V530 Ver:2.1)
- MSI GeForce RTX™ 5090 32G SUPRIM SOC (MS-V530 Ver:2.1)
- MSI GeForce RTX™ 5090 32G Vanguard SOC
- MSI GeForce RTX™ 5090 32G Vanguard SOC Launch Edition
Technical data cooler
Dimensions total (L x W x H)222,40 x 160,81 x 34,12mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs10
Colortransparent
Technical data backplate
Dimensions (L x W x H)222,40 x 132,24 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
€36.98 *
Delivery date: in 7 - 8 weeks
€37.98 *
€25.98 *
€20.98 *
