  • 17483
  • 4250197174831
  • 0,175 kg
€38.98 *
Content: 6 Stück (€6.50 * / 1 Stück)
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
WZS Alphacool Eistools Modding Cutter - Black EOL
€9.98*
ANS Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Chrome
€7.98*
ANS Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Deep Black
€7.48*
29144 Alphacool HardTube Bending Kit Basic
€47.98*
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the... more
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
material Brass
Color White
Height 20mm
diameter 22mm
Thread length 5mm
thread G1/4“
HardTube Size 13mm
compatibility PETG, acrylic, brass and glass tubes
Weight 23g
Download data sheet PDF: Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - White Sixpack
Fitting Map: Here you will find an interactive overview of all Alphacool fittings.
€25.98 *
€20.98 *
€23.98 *
WAC Alphacool Core 1 White
€115.98 *
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
€37.98 *
Content 240 Zentimeter (€7.49 * / 100 Zentimeter)
