Alphacool NexXxoS XP³ screw set - Black
WACZ Alphacool NexXxoS XP³ Schraubensatz - Schwarz
  • 12157
  • 4250197121576
  • 0,078 kg
  • Currently there are 6 available
€3.98 *
Replacement screw set for the Alphacool NexXxoS XP³ CPU water cooler, but also compatible with... more
Replacement screw set for the Alphacool NexXxoS XP³ CPU water cooler, but also compatible with other CPU coolers. This mounting set is characterized by its beautiful black color and slim design.
Technical data:
Knurled nut internal thread: M4,
Dimensions knurled nut (HxD): 8x12mm
Spring length: 15mm, color black
Screws: 4x M4x45mm
Weight: 38g
1x assembly screw set, consisting of: hexagon socket wrench, plastic washers, M4 knurled nut high design, springs, screws
WACZ Alphacool Eisberg AM3 Schaubensatz PHT EOL
Alphacool Eisberg AM3 screw set
Content 4 Stück (€0.37 * / 1 Stück)
€1.48 *
€6.49 * €8.98 *
€1.79 *
Alphacool Core thermal pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.81 * / 1 cm²)
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x3mm
Alphacool Core thermal pad Soft 6.2W/mk 40x40x3mm
Content 16 cm² (€0.56 * / 1 cm²)
€33.98 *
€29.98 *
21%
€33.97 * €42.98 *
