Alphacool Core XP³ Acetal
- Article no.: WAC
- EAN: 4250197130585
- Weight: 0,54 kg
The Alphacool Core XP³ Acetal is a very compact CPU water cooler for all common mainstream sockets from AMD and Intel. It offers the typical high Alphacool quality paired with excellent performance at an affordable price.
High cooling performance thanks to optimized cooler base
The nickel-plated copper cooler base has a surface area of 56 x 56 mm with a cross-slot structure and pins that are only 0.4 x 0.4 mm thick through which the water can flow. Due to the extremely large cooling surface, the water can effectively absorb and transport the heat from the cooler base. The pin surface is around 27.6 x 37.6 mm. This means that all mainstream CPUs are cleanly covered, which ensures high cooling performance. The new multi-slotted nozzle plate was specially developed for this cooler in order to achieve a perfect interplay between the water flow and the flow to the base plate. Only the interaction of all these small details enables maximum performance.
Quick assembly
The support frame is simply placed over the CPU cooler. All mounting screws can be pre-mounted on this. The cooler is then screwed on with the mounting screws that are inserted from behind over the backplate. To make installation easy and understandable, well-illustrated instructions with large render graphics are included.
Intel: 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066
AMD: AM5 / AM4 / AM3+ / AM3 / AM2
Technical data | |
L x W x H | 73x63x21mm |
Weight | 113g |
Maximum working temperature | 60°C |
Radiator base material | Nickel-plated copper |
Material cooler | Acetal |
Connections | 2xG1/4" |
Anschluss: | 2x G1/4" |
Abmessungen (L x B x H: | 73 x 63 x 21mm |
Sockel: | AMD AM3(+);AMD AM5;AMD AM4;Intel 115x;Intel 2011(-3);Intel 2066;Intel LGA 1200;Intel LGA 1700; |
Material Deckel: | Acetal; |
Liefertermin: in 6 - 7 Wochen
