Alphacool icicle temperature sensor flat G1/4 - chrome
  • 17597
  • 4250197175975
  • 0,022 kg
SEN Alphacool Eiszapfen temperature sensor G1/4 IG/IG & with AG adapter - Chrome
€15.98*
WZS Alphacool Eiszapfen Acrylic/Acetal Inline Filter G1/4 IG
€9.98*
SEN Alphacool temperature sensor Square Acetal
€14.98*
SEN Alphacool ES flow and temperature sensor "HighFlow" with speedometer signal
€39.98*
SEN Alphacool Core temperature sensor G1/4 IG/IG with C/F display - Deep Black
€21.98*
The Alphacool Eiszapfen temperature sensor flat G1/4" is a simple water temperature sensor that... more
The Alphacool Eiszapfen temperature sensor flat G1/4" is a simple water temperature sensor that can be easily integrated into any water circuit.
Integration made easy
The temperature sensor is very compact and can be integrated into any water circuit thanks to its G1/4" external thread. It is simply screwed into the corresponding G1/4" connection at any position in the water circuit. Due to the small screw-in depth, it is compatible with all Alphacool products with a free G1/4" connection.
sensor
A classic NTC 10 kOhm thermistor is used as the sensor. The readable temperature range is between -40 and 125°C. The cable is 40 cm long and ends in a typical 2-pin connector. Many mainboards now offer direct connection options for such sensors. Please check the manual for your mainboard. There are of course also various external controllers that offer a connection for the sensor.
design
The design is kept as simple as possible so that the temperature sensor can be installed almost invisibly in the system.
G1/4" female connections
H x D 17mmx18mm
material Brass
Color chrome
Cable length 40cm
Connection 2-pin
Thermistor NTC 10 kOhm
thread G1/4" female
Thread length 5mm
Total screw depth 13mm
RT Sensor Table: Open the PDF
1st page: G1/4" external thread
2nd page: Unavailable
Connector: 2Pin
Thermal resistance (at 25 degrees): 10 kOhm
€34.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Liefertermin: in 8 - 9 Wochen
SZ Schlauchabschneider
hose cutter
€6.29 *
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Content 6 Stück (€2.16 * / 1 Stück)
Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
€29.98 *
