Alphacool Apex PCI-e 4.0 Riser cable - 20cm
- Article no.: 17636
- EAN: 4250197176361
- Weight: 0,15 kg
The 20cm long Alphacool Apex PCI-e 4.0 riser cable enables flexible and individual positioning of the PCI-Express x16 slot inside or outside the case.
Flexible application!
Should the graphics card be changed regularly, the riser cable helps to spare the PCI-Express slot of the mainboard. Therefore the cable is very suitable for testbenches and causes no performance loss within the 4th PCI-e specification. Due to the 20cm cable length, plenty of available space for PCI-e expansion cards is available, which greatly increases the mounting options.
Suitable for modding!
The high quality Apex PCI-e 4.0 riser cable from Alphacool also scores in modding projects. Due to its six cable strands, a high flexibility and durability is guaranteed. Thus, for example, the graphics card can be mounted upright. In addition, the cable is very suitable for SSF cases due to its length.
| Technical data | |
| Cable type | connection cable |
| Connector 1 (internal) | PCIe (16x) Plug |
| Connector 2 (internal) | PCIe (16x) Socket |
| Length PCI riser cable | 200 mm |
| Compatibility PCI riser cable | PCIe 3.0 x16, PCIe 4.0 x16 |
| Connector angled | no |
| Cable sleeved | no |
| Cable colour | black |
| Connector colour | black |
Delivery date: in 3 - 4 month
Delivery date: in 2 - 3 weeks
