Phobya 4Pin PWM to 8x 4Pin Splitter
- Article no.: LZ
- EAN: 4049469174064
- Weight: 0,054 kg
With this PWM splitter from Phobya, it is possible to supply up to 8 PWM fans with power at the same time and also to transmit the PWM signal from the first fan to all 8 fans. This makes sense for large radiators, for example.
The splitter is very compact and can be easily installed in the housing. The adhesive tape on the back allows the circuit board to be attached anywhere in the housing, but it can also be attached using two screws in the holes on the outside.
1x circuit board
1x adapter cable
1. Seite: | 1x 4Pin, 1x 4Pin PWM |
Bauform: | Y-Kabel |
Hersteller: | Phobya |
2. Seite: | 8x 4Pin PWM |
Liefertermin: in 2 - 3 Wochen
