Phobya Lüfterfilter 120mm - schwarz
  • LZ
  • 4049469131470
  • 0,059 kg
€3.98 *
Fan filters do not only keep the system clean, they are also optically very appealing. Phobya... more
Phobya tackles an old problem, dust, with revised technology. This filter highly effectively removes dust from the air passing through it. The unit consists of 3 pieces for easy maintenance and cleaning.
The first part, the front, features a clean and straightforward design without visible screws. This part protects the system from large pieces which could be sucked in. Another positive effect is that the front frame prevents possible injury from the fan blades. The front frame can be removed and is connected to the back piece with a clip-in system.
The rear is the counter piece to the front frame, which fixate the filter itself. The rear piece also features the practical and good-looking hexagonal mesh design of the front frame, safely holding the filter unit in place. The rear also holds the mounting screws which are completely covered and invisible when the filter is assembled.
The middle piece is the filter itself. Fine enough to keep even the smallest particles out of your system, but coarse enough to not obstruct the airflow significantly. The filter unit can be removed completely, hence making cleaning quick and easy.
Technical specifications:
Material: Plastic
Colour: Black
Dimensions: 121x121mm
Thickness: 11mm
Extent of delivery:
Phobya fan filter 120mm - black
Note regarding side-by-side installation:
This filter is a bit larger than the 120mm fan to avoid obstruction of air flow. When mounting the filter on radidators it hence does not fit at first. For mounting on radiators the sides of the filters must be shaved down to allow side-by.-side mounting.
This product has been reviewed for you:
chlodzenie (pl)
Farbe: schwarz
Magnetisch: Nein
Hersteller: Phobya
Spezifikation: Lüfterfilter;
Größe: 120mm;
LZ Lüfterfilter 80mm Farbe silber
€2.19 *
LZ Lüfterfilter 92mm Farbe schwarz
€3.49 *
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
€5.68 *
Content 30 Zentimeter (€16.60 * / 100 Zentimeter)
€4.98 *
€11.98 *
Hint!
LZ Phobya 4Pin PWM auf 8x 4Pin Splitter EOL
€8.48 *
Hint!
KAB Phobya 24Pin Netzteil Verlängerung Einzel Sleeving - Schwarz 30cm EOL
€2.58 *
Content 15 Zentimeter (€33.20 * / 100 Zentimeter)
€4.98 *
€4.98 *
L12 Alphacool Rise Aurora 120mm Lüfter Weiß (120x120x25mm)
€15.98 * €21.98 *
Alphacool radiator screw 12x M3x30mm/M3x5mm grey phillips flat head
Content 24 Stück (€0.17 * / 1 Stück)
€3.98 *
RAD Alphacool NexXxoS HPE-45 Full Copper 120mm Radiator
€83.98 *
ANF Alphacool ES D-Plug 25,5mm G1/4 AG auf G1/4 AG - Chrome
€7.68 *
PUM Alphacool Rise Flat Reservoir DDC mit DDC310 Pumpe
Alphacool Rise Flat Reservoir DDC with DDC310 pump
€129.98 * €149.98 *
Alphacool Universal feet for radiators
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
WAC Alphacool Eisbaer Aurora (Solo) - Digital RGB
€74.98 *
KAB Alphacool Eis-Matrix Verbindungskabel - 10cm EOL
Alphacool Eis-Matrix connection cable - 10cm
Content 10 Zentimeter (€15.90 * / 100 Zentimeter)
€1.59 *
RAD Alphacool NexXxoS XT45 Full Copper 480mm Radiator V.2 PHT EOL
Alphacool NexXxoS XT45 Full Copper 480mm radiator V.2
€109.98 * €136.98 *
SZ Alphacool Silicon Bending Insert 150cm für ID 3/8" / 10mm HardTubes - Blau
Alphacool Silicon Bending Insert 150cm for ID 3/8" / 10mm hard tubes - blue
Content 150 Zentimeter (€9.32 * / 100 Zentimeter)
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - Klar 1m (3,3ft) Retailbox 100cm
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 1m (3,3ft) Retailbox
WAC Alphacool Eisblock XPX CPU - Deep Black
Alphacool Eisblock XPX CPU - deep black
€45.98 *
Alphacool HF 13/10 compression fitting G1/4 - deep black sixpack
Content 6 Stück (€4.66 * / 1 Stück)
€27.98 *
Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 - knurled - deep black sixpack
€33.98 *
KOI Alphacool Eissturm Hurricane Copper 45 2x140mm - Komplettset EOL
€215.39 * €249.98 *
Alphacool pump stand for Eisdecke/Eisbecher Series - black
Content 2 Stück (€3.99 * / 1 Stück)
SZ Alphacool Acrylrohr- und Schlauchentgrater - Light Version
Alphacool Acrylic Tubing Pipe Reamer - Light Version
Hint!
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 60cm EOL
€5.28 *
ANF Alphacool HF Verlängerung G1/4 auf G1/4 20mm - Deep Black
Alphacool HF extension G1/4 to G1/4 20mm - Deep Black
€2.78 *
ANF Alphacool HF Verlängerung G1/4 auf G1/4 20mm - Chrome
Alphacool HF extension G1/4 to G1/4 20mm - Chrome
€2.78 *
€1.88 *
